Cable TV card
6 Nov 2005
Oxford
Has anyone made a cable TV card? The only solution I can find is plugging the cable box into a general video input and using the cable remote to change the channels. However I realy wanted to have the whole thing working on a mouse to remove the pile of remotes that build up.
Sry if this is the wrong section btw. It was the closest I could find.
Cheers Jack
Has many one made a cable TV card? The only solution I can find is plugging the cable box into a general video input and using the cable remote to change the channels. However I realy wanted to have the whole thing working on a mouse to remove the pile of remotes that build up.
Cheers Jack
Look for DVB-C cards. I don't think it's an ideal solution though as you won't be able to (easily) use a viewing card with it.
