1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Can anyone advise a sound card for lowest latency playback with USB MIDI Keyboard Sibelius input?
Discussion in 'Sound City' started by UberTiger, Jan 3, 2019.
  1. UberTiger
    Mobster
    I've been trying to reduce the latency when recording keyboard input to Sibelius for a friend. There's a bit of lag between the input and the playback of the sound through the speakers, which is incredibly distracting when there's multiple other instruments also playing back while adding to a new instrument.
    I managed to knock the latency down from about 96ms to 42ms by playing with the Audio Engine Options in the settings and this has helped a lot, but I'm wondering if it can be better. The Sibelius site recommends using an ASIO option, which isn't available on the built in sound on the motherboard.
    Can anyone recommend a good sound card for this?
    Is the ASIO implementation likely to be better on a more expensive vs a less expensive card?
    Can anyone who has used this setup advice how much of an improvement in latency this could provide?
    Thanks
  2. DataVampire
    Wise Guy
  3. UberTiger
    Mobster
    Ohh, looks interesting. Thanks, will give that a shot first.
  4. DataVampire
    Wise Guy
    Let me know how you get on with it
