can you help me better my memory please
27 May 2007
Kent
I have a Asus Rampage Formula with 3 sticks of OCZ DDR2 PC2-8500 / 1066 MHz / Reaper HPC Edition / Dual Channel, CPU is a Q9550 clocked @ 3.6ghz
and memory is set @ 900Mhz 1:1 ratio.
I am not very good at all overclocking but if i try to run memory @ 1066 it would BSOD so for me it easy just to drop the memory to 900, Now on Windows Experience Index i get a score of 5.9 for memory everything else is at 7.9-7.8
Is there anything i can do to better my score with existing memory or should i buy better memory ?
Any help in this would be great thanks :)
What is the recommended vdimm for the modules and is it running at that?
The vdimm should be on the modules itself and what it is currently running will be in the bios.
Also the increase in ram speed will have a negligible effect on real world performance so unless it is bugging you I wouldn't worry about it too much.
