Can't get sound on DS3!
12 Oct 2003
Leicester
Hi,
i am trying to get my onboard sound working!
I did the express install from the cd, but it didnt work.
It says i need to install the microsoft UAA when i try and install the drivers but i have already done this. any ideas?
Thanks
Nevermind, problem solved. for anyone else with problems see below.
1 After Downloading the latest HD Audio Driver, run setup.exe and then reboot (setup.exe will install kb888111xpsp2.exe patch for windows xp SP2 automatically)
2 restart your machine
3 if your audio still not work, Right click at My computer, select manage, at left panel select "Device manager",
4 go to "System Device", you'll see yellow mark on the device named "PCI Device", right click at the "PCI Device", select update driver
5 select your Realtek HD audio driver path and go to Directoty "WDM" such as c:\driver\audio\HDAudio\WDM and then click open
6 Windows will install Microsoft UAA Driver , and install your HD Audio driver automatically
7 reboot your machine again
8 enjoy your cool music
