Can't get sound to work?
Permabanned
2 Apr 2007
Got Vista and installed it but I have onboard sound and can't seem to find correct drivers:
Realtek High Definition Audio (Azalia)
Thats pretty much the sound I have and I can't actually seem to get any download links that work :(. Any ideas? Cheers.
Where did you try the download links? The motherboard support site or the realtek site? You will probably find the latest drivers on the realtek site, as most motherboard vendors have seriosuly out of date drivers.
Where did you try the download links? The motherboard support site or the realtek site? You will probably find the latest drivers on the realktek site, as most motherboard vendors have seriosuly out of date drivers.
Well I tried realtek, but the problem was that even when I install the drivers it says its installed but the system still says theres no sound drivers :S.
Installed it under recommended, and restarted the computer, but it still says there is no sound driver and of course I get no sound.....:mad:
