hello all
I want to upgrade the speakers and headunit in my alfa 147.
i have a budget of 400.
im a complete novice when it comes to car audio.
I want to upgrade the 4 main speakers and 4 tweeters, which i belive are 16.5 and 1" for the tweeters, any one with an alfa Is this correct? i want to keep the speakers in there original position.
i have read that some speakers will not fit as they are too deep, with out taking the current ones out i have no way of finding out the maximum depth of speaker i can use, so if any one knows please tell.
ive been looking at the FLI Integrator COMP6.
quick question here. whats the difference between component speakers and full range speakers?
i want a head unit that has USB so was looking at the Sony CDX-GT50UI.
because i dont want a sub and amp at the moment i am planning on running all 8 speakers of the head unit, is this ok?
Cant think of any more questions at the mo, just want your opinions on what i have said, or if you can advise on something better.
thanks.
thanks.
