Well it's either burning it or leaking it. Burning that amount is going to be either the valve stem oil seals or the rings. Given it's using that much you can kind of guarantee it's been run low in the past which is going to have caused more than the usual day to day wear.
Personally if it is not leaking it I agree with the get rid of it post. Even if you get the parts repaired you may still end up with major bearing failures in the future.
You need to weigh up what in worst case, a new engine will cost you against depreciation loss. Sometimes the later is less hassle in the long run. However get it checked out independantly first.
