Case for watercooling big enough for 2 3x rads
The position of the heat sources in the loop does not make any significant difference as the heat throughout the loop will equalize after a short amount of time, so I wouldn't waste my time changing the flow order.
this is true in a sense but if you wanted to lower temps on the cpu a little and put it onto the card i would swap it to cpu/gpu/res etc
change the fans and then go from there
It is marginally better to go cpu>gpu but as has already been said it makes virtually no difference once the water temperatures have equalised anyway.
