- 8 Feb 2007
I'm going to be buying an E2220 to overclock and an 8800 gts 512 because its not that much more expensive than an 8800 gt. The motherboard will be a Gigabyte GA P35 DS3L. PC Gaming magazine ran a review of this motherboard a month or two ago and said that the northbridge and southbridge got "exceedingly hot".
Would a good size side fan help with this problem? OC sell the Xclio 6030 Plus at £35 (stock code CA-023-OK if you're interested) that has a massive 360mm fan with adjustable speed for silence versus cooling. The fan is "outside" of the case so my Arctic 7 pro fan should fit nicely.
Question is, is this type of fan just overkill for an overclock and would a nice looking Coolermaster with a fan in the front be just as good.
Thanks for any help with this.
