- 29 Aug 2018
I am looking online and seen a lot of threads that indicate that the small case contributes to increasing the temperature so I was considering buying a mid tower? Any suggestions? Also is it wise to upgrade the motherboard from a micro considering my build:
Also can anyone tell me how many fans additional fans I can additonial use with this build - I purchased x2 £4.99 coolmaster 120mm fans to place on the top and I'm looking to buy x2 140 Corsair CO-9050035-WW Air Series SP140. Will these be able to run on my build. The fans plug into the motherboard? I have a micro one in this build so I hope that doesn't limit me.
My basket at Overclockers UK:
- 1 x AMD Ryzen 5 Six Core 2600 3.90GHz (Socket AM4) Processor - Retail= £149.99
- 1 x Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD416G30= £99.95
- 1 x CoolerMaster MasterBox Q300L Micro-ATX Case - Black Window= £44.99
- 1 x WD 1TB Blue 7200rpm 64MB Cache Internal Hard Drive (WD10EZEX)= £38.99
- 1 x UD PRO 256GB SSD 2.5" SATA 6GBPS TOSHIBA 3D NAND SOLID STATE DRIVE= £49.99
- 1 x MSI Radeon RX 570 ARMOR OC 8192MB GDDR5 PCI-Express Graphics Card= £158.99
- 1 x Gigabyte B450M-DS3H AMD B450 (Socket AM4) DDR4 Micro-ATX Motherboard= £69.95
- 1 x Bitfenix Formula Series 550W 80 Plus Gold Power Supply= £66.95
