1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Caselabs BH4 - Water Cooling Issue.... HELP!
Discussion in 'Watercooling' started by Rasphelt, Nov 25, 2018.
  1. Rasphelt
    Gangster
    Hi Guys,
    I have built another Caselabs (RIP) BH4 mATX build - this time with a 1080ti and 8086k - fully custom cooled. I have a horizontally mounted EK XRES 100 to the rear fan are at the back of the case.
    Here is my problem - I cannot seem to get it to run without air bubbles in the loop for any amount of time... I have emptied and refilled the loop several time for it to be fine for a bit and then low and behold there are the bubbles again.....
    Any ideas please?
    Cheers
    Ras
  2. Dirk Diggler
    Capodecina
    Need photos in order to help, although I suspect you've left the air with nowhere to go.
  3. Rasphelt
    Gangster
    There is a small amount in the loop, at the top of the res, and i think that means that the it circulates through the loop when horizontally mounted. If so, then surely that is a design flaw?
  4. Dirk Diggler
    Capodecina
    Post a little photo as I'm struggling to picture it exactly.
  5. CageyH
    There is more air in the loop after it has been run for a while?
    Is it properly bled? If so, you have an air leak.
    I have run the EK res horizontally without problems.
    Is yours a pump/res combo?
  6. UnLuckyBenski
    Mobster
    If you just mean air bubbles clinging to the sides of the reservoir, I've found those can take a few days to let go and find their way to the air pocket at the top. Quite annoying when you're finally filling your loop!
    Otherwise let's see some photos :)
