Catalyst 10.3 improves CrossFireX performance in Dirt 2 by more than 25%:
hopefully they'll get crossfireX sorted altogether; with the 10.2's it becomes a slideshow, whereas standard crossfire works brilliantly. 10.3 pre's cause all sorts of glitches in crossfireX
This is NOT true if you run on a single screen - it is a problem however with Eyefinity .. i.e, for Dirt2 on Ultra:
Single screen - 5970+5870 8xMSAA @ 1920x1080 = 152fps
Eyefinity - 5970+5870 2xMSAA @ 1920x1080 = 23fps!!!
5970 on its own for Eyefinity @6000x1080 with 2xMSAA = 56fps .. (Any more FSAA and slide show due to 1GB memory limit)
Have also tried Unigine benchmark, stalker(s) and COD MW2 on the 10.3 drivers with similar results scaling wise ..
sorry, i should have stipulated that :)
although i figured you'd have read my sig to realise i use eyefinity
