CBR600 F3 (96) Clutch question
might aswell,idk if its aftermarket clutch or genuine,from what folks have said on here the genuine ones last longest,but they might be more expensive
It's a Honda so genuine parts are easily going to be more expensive. But any time I've had genuine parts you can tell the difference, Eg brake pads
Well it's taken 2 and a bit hours and cost me 3 fairing bolts but I've changed the clutch cable. I'll have to test it tomorrow as I ran out of time tonight. Think it needed changing tbh lol
http://i722.photobucket.com/albums/ww223/mowytone/Mobile%20Uploads/DSC_0052.jpg[/IG][/QUOTE]
Someone buy this man some ACF50 please
I bought the bike in a hurry as I knew the engine in the SV was dying. I was in such a rush that I grabbed something I could afford and in a hurry.
It's a CBR600F 1996 with 55K miles....no doubt by the look of her internals she has done every winter going. I'm counting her as a learning bike as she is my 2nd big bike and I;m doing as much of the work as I can myself.
There is no doubt that this bike as not been loved by it's previous owners, but still she goes really quite well for her age and I am chipping away at the issues that I find :)
I see it has a manual cam chain adjuster, auto cam chain adjuster failure is common problem with the cbr6
mine failed at 37k
I'm going to take a guess that the manual adjuster is the bolt sat at the top of the thread on the right, slightly obscured by the clutch cable?
That's good to know as I think it needs adjusting as there is a ticking coming from the right hand side of the engine that speeds up with the engine revs.
Good news is I didn't balls up the clutch cable and I was able to ride it in this morning without making any adjustments at the road side.
Bad news is the clutch still drags
Yes, you undo the lock nut and give bolt a turn, not much though, maybe a quarter if that and not with the engine running.
Bugger about the clutch still dragging
time to look in the case I guess
As above undo the lock nut and turn it slowly, you will hear the engine noise change, when it does back out slightly and lock the nut back up.
I would take off the inspection cap if it has one on the clutch side and play with the adjusters there to see if you can stop it dragging.
Im only up the road in Eastleigh if you ever need a hand mate,
One method with the engine running and one with not?
Cheers mate I may well take you up on that as I don't have any experience with clutches yet
if it sounds tappy id start with an oil change after you change the clutch ( because oil will come out when you remove the clutch casing ) oh and get a new gasket.
they are pretty tappy at the head when they get past 30k mark could well be but id start wit the oil change before adjusting the tensioner. it could also have warn runners
