Forums show people using 10w/40 for road and 10w/30 for track. most say to avoid fully synthetic. I don't know whats in there but I've topped it up with semi
Could this be mis-adjusted clutch springs?
you cant mis-adjust the springs.
Most bikes there is no adjustment on the springs. you just do them up all the way
Well On testing this morning it appears that the clutch drag is only present when the bike is warm.
Unlikely to be an oil problem then.
It could just possibly be caused by uneven spring pressure i.e. one spring of the set (I think the old 600F uses four springs) has gone weak or is broken This would mean the clutch pressure plate wouldn't get released evenly. It could also be a warped steel plate that gets worse at high temperatures.
Time to get the clutch cover off and take a closer look, it's not a difficult job.
Note that the clutch cover gasket may well come off in bits, so if you need the back back together and working quickly it would be worth ordering a new gasket (pattern ones are generally fine).
So to be sure swap the whole lot out by the sounds of it
That won't be the cheapest option, springs, friction plates and steels will be ~£70 for pattern parts. A new clutch basket will be ridiculously expensive, so a good s/h one is probably the best option if this the problem.
I'd get the cover off and inspect everything to start with, maybe take a few pics and put them on here. If you get a gasket then you can put it all back and keep it on the road whilst you order any replacement parts that may be needed.
Do you have a garage at yours? if not better bring it to mine incase its raining![]()
Good luck guys
