** CHRISTMAS POWER SUPPLIES **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Its Christmas guys! Oh wait just the adverts on TV have started, anyway there has being many request for White Editions of the Superflower PSU's in the regular GOLD versions. We listen to our customers and they will hopefully arrive sometime this week:
SuperFlower Leadex GOLD 1000W Fully Modular "80 Plus Gold" Power Supply - White @ £149.99 inc VAT
Leadex series PSU are 80+ Gold certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features:-
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Gold Certified, 90.43% 92.03% 90.27% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Speciication:-
- Type: ATX
- Maximum Power: 1000W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable: Yes 100% modular cable design
- Input Voltage Full Ranage - 100V~240V
- Input Frequency Range 50 ± 3 Hz / 60 ± 3 Hz
- Output +3.3V@24A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- Protection OVP?OCP?OPP?SCP?UVP
- Dimension 200mm(L) x 150mm(W) x 86mm(H)
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 8-Pin EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £149.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 850W Fully Modular "80 Plus Gold" Power Supply - White @ £119.99 inc VAT
Features:-
Speciication:-
- Type: ATX
- Maximum Power: 850W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £119.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 750W Fully Modular "80 Plus Gold" Power Supply - White @ £99.95 inc VAT
Features:-
Speciication:-
- Type: ATX
- Maximum Power: 750W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £99.95 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 650W Fully Modular "80 Plus Gold" Power Supply - White @ £85.99 inc VAT
Leadex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features:-
Speciication:-
- Type: ATX
- Maximum Power: 650W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Output +3.3V@22A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- 1x 8-Pin EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £85.99 inc VAT.
ORDER NOW
Lovely looking units and as always same fantastic Superflower build quality! :)
Roverno said:
As a bit of a silent freak, TTLs review has put me off a little. I like my silence/near silence.
I always leave it to the experts when it comes to reliable PSU reviews i.e. OklahomaWolf @ Jonnyguru website and crmaris @ Techpowerup.
Use ECO mode. The fan does not turn then.
Also TTL was being super critical and did actually say it was quiet in operation just not the quietest he had heard, but in ECO mode the fan does not turn.
I've got a 1000W Platinum at home powering an FX-9590 and R290X and in ECO mode the fan only ever start to rotate when gaming or benchmarking. Web browsing or watching videos the fan stays powered down in my system.
I am an avid watcher of TTL and also very critical of fan noise and have to say I disagree with him on that particular video as well. I upgraded from a Silverstone Strider Gold 850W to the 1200W white model. It's probably overkill for my set up consisting of 2x HD6950s x-fire with an i7 4820K. All watercooled by EK waterblocks for eveythinging including mobo, 1x360mm, 1x 240mm rad and 5xGT fans but the fan has never turned on at all and if it has I haven't even noticed it making any noise above the GT fans (which are as silent a fan as I've ever had).
One thing I will say is I get some very strange alerts coming from the Asus motherboard suite of utilities about the voltages and low temps of the motherboard chips, etc. but I'm chalking that down to the software being weird itself and just picking something up wrong... as the machine has been rock solid and I very highly doubt that the motherboard sensor is accurately detecting minus degree temps - i don't have a chiller in the loop. But possibly some of the power saving measures it does in EVO mode causes it to think there are voltage problems?
I dunno about that but I'm more than happy with the PSU, it looks great, its silent and I know if I put some power hungry video cards in there it has the overhead to take them. Sorry TTL.
