Cleaning aftermarket air filters
31 Oct 2002
Newcastle upon Tyne
I've got an ITG air filter on the Elise so I was wondering what the protocol was for cleaning it.
Some people say soap and water will do, followed by re-oiling, some reckon you need to degrease it, then re-oil so I thought I'd ask the clever people at OCUK to get a definitive answer :)
Permabanned
16 Sep 2006
The Pant Store
Firstly, LMAO. Thats a risky game providing a stated power increase. Is it a guaranteed increase?
A light coating of air filter oil but not too thick or you could damage the MAF
8 Sep 2003
Outside
I did mine on the FTO a few months ago. Took it off in soapy warm water (not hot), scrubbed it/mauled it a bit. Had to do a few sink loads of water to clean it.
Don't leave it to soak, it'll kill the glue.
After that, I let it dry overnight (important, don't use a hairdryer), then regreased it and shoved it back on.
Apparently if it's really hard to clean, use a solvent like petrol to shift the muck.
19 Oct 2002
Jupiter
IIRC if you use petrol, it dissolves something inside the filter, however how much truth there is to this i'm not sure :confused:
8 Sep 2003
Outside
Petrol should be ok... just don't leave it to soak. The glue tends to fall apart due to heat. The ITG manual even said to use petrol!
Never tried it though
18 Oct 2002
Newcastle Under Lyme
Foam filters are nice and easy to clean in general. Pipercross do good foam cleaning kits, they're only a few quid.
One thing to remember is when washing the water through the filter, do it from the inside out! Otherwise you're pushing dirt into the filter rather than pushing it out. Other than that, get a brush on it, leave it to dry, reoil, refit. Dead easy :)
Don
18 Feb 2003
Brighton/West Wicklow
I've done my maxogen before, just remove the internal filter and wash in warm water - dont leave it to soak but just gently knead it and keep changing the water until its clean. I then left mine in my airing cupboad overnight and then sprayed a moderate coating of the dust retention spray on. Don't be too heavy handed with the spray however.
Top
