I need to take my loop apart to fit a new GPU and was going to use opportunity to clean out all my blocks and re-paste.
EK suggests using a soft non abrasive automotive metal cream to polish nickel plated blocks.
Would autosol do?
Also I may have used vinegar to clean the nickel blocks once before I can’t remember - apart from tarnishing the plating would it have had any lasting effects (some autosol and an old toothbrush couldn’t fix??).
How do you guys clean your loops/blocks?
Also are there any coloured coolants that don’t stain?
Thanks
Dave
Would autosol do?
Thanks
Dave
