Clueless Network Problem
6 Oct 2007
Liverpool
Yestaday i came home (computer already on)
Yet had no internet connection... tested iPhone worked fine, Laptop worked fine. Just my PC... did a restart can often solve issues had it had been on for a while.
seemed fine for about an hour then loses connection...restarted router and checked settings but nothing tries to connect but results in limited connectivity on unidentifed network.
If i disable and re-enable adapter it works straight away for about 15 mins then dies again :confused:
can't think what would be causing this?
(tried diffrent cable aswell)
EDIT: Has something to do with the xbox... I recently tried to fix the streaming video on dashboard rather than WMC, as it is crap. each time i try to stream something the PC loses its Default Gateway (Router)... why would streaming media kill the connection between PC and router?
this is anoying.
Streaming music could cut the connection but shouldn't cause you to lose the default gateway.
Have you done an ipconfig when this happens?
Don't know if these'll help:
ipconfig /renew
ipconfig /release
ipconfig /flushdns
