Coil Whine - VTX 7970 B-Grade.. Do I return?
18 Aug 2005
Shropshire
Bought a 7970 VTX out of the B-Grade section for £240.
Just installed the card, as soon as the card is under load (In game) there sounds like 1000 crickets living inside my pc.
Do I return under DSR? :( Thanks
3 Feb 2012
Peterborough
Run it overnight on Heaven to see if it helps. If not - and you're not happy with it - then yeah return it. It probably safe to say that's the reason the original owner returned it.
Can't help to try the above though.
If you sleep in the same room as your PC then I'd just send it back now if it's that bad. :(
18 May 2003
Always a risk with the B grades, they have been DSR'd for a reason, the best hope is due to incompatibility with other kit.
30 Mar 2010
Under The Stairs!
Another option is to split the power draw on the gpu if you have separate pci-e cables.
1 cable for the 8 pin, and the other cable for the 6 pin, it worked for me on a 7970WF that had coil whine.
OP
18 Aug 2005
Shropshire
I already have it like that Tommybhoy, I have an OCZ 1250w with seperate cables.
I might just apply for a returns number and drive to the shop this weekend to drop it off and return it.
Caporegime
24 Sep 2008
Essex innit!
On my second Lightning, I could hear the phase capacitors to the point of worry (after putting on water blocks) but after a few decent sress tests, I can no longer hear it. I would say bash out some Heaven/3DMark11 for a couple of hours and see if that helps but push the GPU to the max.
Maybe my sound was different though but worth a shot.
5 Nov 2010
100% sure it's the graphics card.
I thought my GTX580 had coil whine. Turned out to be my OCZ ZX1000 screeching.
27 Aug 2008
London
Bad luck TaKeN. I'd check the psu as rossi says (my spare psu gets whiny under moderate laod), but yeah if its the card and you find it intrusive then send it back. No point keeping it if it's going to bug you all the time.
edit: And im not just saying that because I was eyeing it up before :p
I can't stand noise either but for anyone who doesn't mind it, it's still a bit of a bargain I guess.
OP
18 Aug 2005
Shropshire
Ok, just put my MSi 6950 back in and that doesn't produce the same noise (Under the same test situation)
So I'm guessing it's the 7970 at fault?
5 Nov 2010
Which uses more power?
It probably is the 7970 causing it but a lot of the time it's the PSU and can easily be mistaken.
3 Jun 2012
no... its the 7970
ALOT of 7970's have coild whine, I went through 4 untill i landed on the asus DC2 which has 0 coil whine.
28 Oct 2005
Scotland
I too got a VTX 7970 in the B-Grade section...only coil whine I've heard is an extremely brief second or two as Heaven loads, everything else, nothing!
5 Nov 2010
The OCZ ZX are dreadful PSUs.. I hate mine, whines non stop.
Only happened once I got SLI and broke a certain wattage barrier...
They are actually brilliant PSUs, the coil whine is the only negative point to it. Tis an annoying issue i must admit.
OP
18 Aug 2005
Shropshire
The 6950 should be pulling a similar wattage to the 7970 surely?
The 7970 are a more power efficiant revision. So should be drawing less wattage clock for clock??
