Compucase CF-V12H Cougar Fans
Permabanned
1 Aug 2010
Compucase CF-V12H Cougar Fan with Hydro-Dynamic Bearing,MTBF300,000hrs and Super Silence
  • High quality IC controls the motor
  • Dimension:120x120x25mm
  • Weight:N.W.135g,G.W.210g
  • Speed:1200R.P.M.
  • Bearing:Hydro-Dynamic Bearing
  • Air flow:60.4 CFM 102.6m3/h
  • Air Pressure:1.73mm H2O
  • Voltage Range:4.5-13VDC
  • Connector:3 pin
  • Acoustical Noise:17.7dB(A)
  • Life MTBF:300,000 hours
The specs on these seem too good be true, ive tried looking for reviews but i cant see any. Does anyone know if these are any good for £14.49?
