crashuk said:ok i see its connected to your usb port,
get a network cable and connect it to the pc and to the router, then do a ip config / all again. and take pic again.
http://i81.photobucket.com/albums/j201/the_eds/ddd.jpg
tolien said:That's screwed up - it should be getting a 192.168.1.x IP the same as the USB interface did.
You could try disabling IPv6 (which is where the weird IPs etc are coming from), but it's doubtful it would fix anything.
That router comes with a cd that runs on a pc, the cd is the routers set up programme via the lan, its setups everything up on the router, all it asks is type of dsl, isp username and password, then it setups up the router so all you need is to connect pcs via the lan and its ready to go.tolien said:You don't need the CD, the machine should just automatically get an IP from the router.
Tried manually setting it to match what the USB interface got (IP 192.168.1.2, subnet mask 255.255.255.0, default gateway 192.168.1.1 etc)?
crashuk said:That router comes with a cd that runs on a pc, the cd is the routers set up programme via the lan, its setups everything up on the router, all it asks is type of dsl, isp username and password, then it setups up the router so all you need is to connect pcs via the lan and its ready to go.
i asked him to reset the router insert the cd run follow the instructions, then we can get onto the wireless part.tolien said:That's all very nice but it's totally irrelevant, especially if (as the OP says), it doesn't do that.
crashuk said:i asked him to reset the router insert the cd run follow the instructions, then we can get onto the wireless part.
Brains said:Before it was mentioned putting the cd in, presumably the router one, but all the router has on it is the crap instructions and the usb driver.
crashuk said:ok now the problem is xp is assigning an emergency ip addy, what you need to do is the di sconnect the phone line from the router, then on the pc disable your firewall and / or windows firewall.
then do this
start ----> run-----> type cmd you should get a black window.
type this ipconfig /release all
then type ipconfig /renew
if that dosent work do this start control panel network connections, and select the lan card right click and click repair. like the pic
then do a screen shot.
op then stat run cmd ipconfig /all
