Hmmmm are either of you running in a RAID setup so maybe it's faster? Or as they running independently? We will only be having one hard drive for now. My brother just doesn't want it to be too slow
Yeah webstation sounds quite cool
EDIT: Just so we can research, what hard drive is one step up from a green one?
Sorry to steal the thread but im in the same boat as azibux, never had NAS before:
Im looking for a good stable NAS system that will hold all my blu-ray / dvds / music pics etc etc. Baring in mind my blu-rays are .MKV files and I have 2tb worth of movies so far.
I will be upgrading my router / network wires to CAT6 and getting a gigabit switch so that I can stream all my movies etc to my HTPC in the lounge and tv in the bedroom.
Do I go for QNAP 4 bay NAS or will the Synology 2 bay NAS be ok with 2x3Tb hard drives.
Is it worth RAID the hard drives?
Scottman - given how much stuff you have stored already I would strongly recommend a 4 bay enclosure to give you that head room assuming your budget allows. Otherwise 2x3tb is your upper limit. Also depends if you raid 1 them or use them as a pool ie 3tb mirrored (giving redundancy) or 1 6tb volume (no redundancy).
Which 4 bay would you recommend? I've just been looking at the QNAP TS-412 Turbo NAS 4-bay, didnt know what spec I will need...I know I wont need top end spec as I wont be video or photo editing every day, only watching movies, listening to music and other basic stuff.
ok thanks for the help, do you know a good gigabit router with more then 4 ports? and a good gigabit switch?
Yep the HP Procurve is worth the money - around £50.
2tb western digital nas or buffalo would be fine
I have a synology ds1511+ and a HP Procurve managed switch. Very happy with both.
Switch details?
