Considering water cooling any advice?
23 Mar 2007
Essex
Hi everyone i have built myself a new machine and i must say im pretty pleased with the way its running this is my spec
NEC AD-5170A-0B 18xDVD±RW DL Black - Bare Drive
Seagate 7200.10 320GB SATAII/300 8.5ms 7200RPM 16MB Cache
ASUS P5B Socket 775 Core 2 ready P965 chipset onboard audio ATX
Intel Core 2 Duo E6600 (2.4ghz) Socket 775 FSB1066 4MB Cache
Microsoft OEM Windows XP Home SP2B
Corsair HX Series 620W Modular PSU - ATX12V v2.2 APFC
Coolermaster Centurion 5 With Blue Trim
Corsair (TWIN2X2048-6400) XMS2-6400 2048MB 5-5-5-12 2X240 DIMM Black XMS2 Heat Spreader
BFG GeForce 8800 GTS OC 640MB GDDR3 HDTV/Dual DVI (PCI-Express)
My temps seem to be ok
CPU idle 32c underload 43c
GPU idle 49/50c underload 59c
MB idle 34c underload 43c
They seem ok to me but i would like to get water cooling soon and just wanted to be pointed in the right direction, i would not no where to start so i hope i have given enough info for someone to help me out
many thanks guys
Those temps seem pretty already :)
What are you wanting to cool? Your CPU and GPU? Once you have decided that there are two ways you can go:
You can buy a kit... these are pretty good:
This - for just cooling the CPU
This - for your CPU, GPU and chipset.
Or the 2nd route you could take it do design a custom build with the parts you actually want. Im sure others can help more but have a read of this and do some research youself. It will help you more.
Just find a good water-cooling specialist and e-mail them for advice. It's a very specialist field and although OcUK stock some water-cooling parts, they don't really have their heart in it.
How many 120mm ports does your case have? That's one big area where you may have to compromise on radiator space or else get into case cutting. Again - a good water cooling specialist can help you out there.
For a cheap, simple rig, try this;
Flow 120mm Radiator (with 1/2" barbs) (£20)
XSPC 400l/hr combined pump and reservoir (with 1/2" barbs) (£35)
D-Tek FuZion CPU block with 1/2" barbs (£38)
Masterkleer 7/16ths tubing (buy 10' as it's handy to have plenty) (£10)
6 12mm jubilee clips (£1.50)
1l Feser One fluid (£8)
That should cost you about £110 all-in and will fit into almost any case with a 120mm radiator bay. Use your existing 120mm fan to blow through the radiator. It should look a bit like this ;)
