1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
Control freeze on Rtx 3090 - is my card unstable?
Discussion in 'Graphics Cards' started by sewerino26, 5 Apr 2021.
  1. sewerino26
    Hitman
    PC:
    Monitor:AORUS FI27Q
    Cpu: 10850K with Nzxt Kraken X73 ( 60c in game )
    Gpu: Rtx 3090 Gaming Oc ( 60C in game )
    Ram: 32gb 2x16 GB DDR4 GSKILL 3200MHZ XMP
    Psu: Seasonic Ultra Prime Titanium 850W TX
    mb: Aorus 490 Pro Gaming
    SSD: Crucial 1TB Nvm SSD
    Case: Cooler Master Cosmos C700P
    So after Battlefield 5 i run Control , 1440P Rt High. When level loaded i turned camera by mouse and game freezed for 3 second with gpu load 0%. After 3 seconds unfreezed and i was able to play. Is my pc unstable or it was game issue? Gpu is not oced.
    I ask because it never happened something like this in this game. I was played many time.
  2. Jacky60
    Wise Guy
    Yes I think the card must be faulty! If the PC were unstable you'd notice other issues, whereas from what you describe the card seems to be dying. I'd RMA it just to be sure.
  3. sewerino26
    Hitman
    happened once after i loaded level before autosaving ( white small wheel turning on right part of the screen when autosaving )
  4. donpyro
    Gangster
    do you have that problem with any other games?
  5. Stickyxfinga
    I was under the impression control wasnt the most stable game. If it hasnt happened with any other games then id assume its the game. I dont see how a 3090 that hasnt been overclocked would die already. If temps are normal, fps normal and it only happens on one game then to me that sounds like a game issue
  6. Drangueos
    Mobster
    Is anything on your pc overclocked?
  7. ltron
    Mobster
    It always does this when launching the game for the first time after installing a new driver, it is building the shader cache. The next time you launch the game it should be smooth.
  8. sewerino26
    Hitman
    Hey that stutter/freez for 3 seconds not happened in other games. Yesterday on Control it happened.
    Happened once after i loaded level and turn camera by mouse, before autosaving. Then i was play and no issues with gpu load. Stable 98%.
    Pc is on stock. XMP only on. .
  9. Josh
    Capodecina
    This guy again.
    Cards clearly dying man, rma.
  10. Jerry64
    Wise Guy
    Lol he is back again bless him
  11. SaBBz
    Mobster
    So it’s literally happened once?
  12. Jacky60
    Wise Guy
    +1
  13. donpyro
    Gangster
    if it hasent happend in any other games thne its more likely the game,your GPU is not dead
  14. Kaapstad
    Man of Honour
    You should put this in anyone of the numerous other threads you have started rather than spamming the forum.
  15. sewerino26
    Hitman
    Its ok i replayed and played some time and no drops.Even left character standing on the same place and observing gpu usage. I guess it was glitch in game on beggining after load or something.
    Thanks for helping me. I really like you guys. Really greatful I am love you all.
  16. koooowweeee
    Put the card in the bin and buy a new one. Only way to be sure
  17. Ravenger
    Mobster
    I had a load of stuttering issues with my 3090 when I first got it. I could never figure out exactly what caused it or indeed how I fixed it. It was some combo of MB bios updates, bios settings tweaks and driver updates.
  18. Figo
    Gangster
    Crank your GPU Fans up to max, knock 100MHz OFF the core clock and drop the VRAM clocks by say 10% and see if you can replicate the issues.
    If you can, your card could be deffective, but going by the other threads you are having other issues with your system that might not be hardware related.
    Have you tried backing up all your stuff and doing a clean windows install and have you ensured ALL your drivers (not just GPU) are upto date?
  19. Neil79
    Caporegime
    Not this guy again :rolleyes:
  20. Neil79
    Caporegime
    Not this guy again :rolleyes:, seriously people stop replying to the OP it's waste of time :(
