Meat + wooden chopping board = DEATH!
Well maybe, seriously you should only use a plastic board for meat as you can wash it thoroughly, e.g dish washer.
I know butchers use em, but thats all they use em for. Looks nice though, might have to try it at the weekend
That looks gorgeous, wouldnt mind giving that a go.
Nonsense. A good wood board is 1000x better than any plasic board. Plstic boards get gouged and fill with dirty muck.
Sieve? pah :
Much easier and makes super smooth mash.
indeed it does, but i cant make food want to make me mine?
that looks stunnin, given me idea mind you because i normally do this with chicken breat stuffed with cheese and wrapped in bacon, ill tie it now, but i do usally boil it for 5 minutes so it holds it shape in the cling film. Then remove cling film and fry with knob of butter
how to you get it to hold its shape? i had real problems getting it to role. I found keeping it in the fridge for 12hrs + helps then like mentioned boiling it for 5 mins before taking cling film off and frying. Ill deffos try wrapping it in rope.
I just rolled it as tight as I could, tied up and slung it in the fridge for a hour.
I didn't cut straight away, it rested for about 10 minutes in the pan before I cut the string off.
Dumb question comming up! you rolled it tight, and tied it with cling film on? because when i roll it tight as possible, then remove cling film it falls apart
