Cooler than the Fonz!
2- replace anti-kink corrugated tubing with smooth wall tubing - improves liquid flow
The other effect of this is to dramatically reduce the life of the product, as the rubber tubes have a much higher evaporation rate than the FEP corrugated tubing. Especially at the temps you'd see inside a computer case.
The product has a 3 year warranty so this should not be an issue.
The product has been rated for typical lifespan of 50,000 hours usage.
How can it restrict? we're not talking silly tiny fish tank air tubes here. The tubes are quite big regardless how they are shaped.
Because of physics?
#1 the tubes are larger diameter
#2 the tubes are smooth walled instead of corrugated. Corrugations cause turbulence, turbulence slows flow through the tube.
i was after a 2nd hand h-50 but after reading the review im so tempted.
i had a h-50 then went to full watercooling then deceided to go back to air....big mistake,after all the air and watercooling systems ive had i actually like the h-50 a lot more.
this new cooler is a good price.
changed my mind and im going to stick with the h-50 due to me having one and knowing what it can do.
