CoolerMaster 690 II Advanced, top lights
26 Dec 2010
Bucks
Recently just built my new computer and just wandering what the two lights above the reset switch mean, tried looking around but not even sure what sort of lights these are. One has a lightning bolt which comes on every time I turn the PC on, so want clarification on what it means. The other one is some sort of cylinder that doesn't light up at all.
The right LED is the power LED. The one next to it is the HDD access LED.
The cables for these should be plugged into your motherboard.
The one that stays on when you turn the PC on is simply a power light and should be on as long as the PC is left on.
The other is the hard drive activity light that should come on everytime the hard drive is accessed.
EDIT: Damn, just beaten to it. :)
Ok thank you very much, just thankful it's not something telling me that there's a problem with a power shortage or something.
Being the first build I was expecting something to go wrong. :)
