** COOLERMASTER V8 GTS COOLER **
rjk
rjk
Caporegime
8 Aug 2007
Cooler Master V8 GTS High Performance CPU Cooler @ £66.95 inc VAT
Its big, It looks mental, It will be in stock tomorrow!
The Cooler Master V8 GTS CPU cooler combines the performance and aesthetics Cooler Master are known for, for a complete solution that matches your every need.
The V8 GTS CPU cooler uses 8 heat pipes and triple tower design to bring you the ultiamte in performance. Along with the 8 heatpipes and multiple towers, the V8 GTS utilises Cooler Master Horizontal Vapour Chamber Technology to reduce CPU hotspots and help to spread the load amongst all 8 heat pipes.
The unique tower design combined with the Red LED 140mm PWM fans means that this cooler can deal with heats up to an amazing 250w TDP. The fans also use durable POM bearings so that they remain dust proof and can see a life up to 160,000 hours.
A universal mounting system sees that the cooler is useable with current Intel and AMD sockets.
Features:
•Cooler Master Horizontal Vapor Chamber Technology – minimizes CPU hotspots and spreads heat evenly to all heatpipes.
•Triple Tower Heatsink with 8 High Performance Heatpipes – Optimized for maximum cooling performance.
•Dual High airflow PWM fans with red LEDs.
•Fan speed and resulting performance and noise can be fine tuned and customized.
•POM Bearing – Dustproof and longer lasting.(up to 160,000 hours)
•Universal Mounting System compatible with all available Intel and AMD platforms.
Only £66.95 inc VAT.
ORDER NOW
the performance isnt the absolute best but it is decent enough.
this cooler is more about the look inside your case. We have already pre sold 10 of the things and it has only been live since I started this thread. :o
Brainception........
Bet you need some ridiculous clearance to fit that in.
Sizes (from their site)...
Dimensions (LxWxH) 154 x 149.8 x 166.5mm (6.1 x 5.9 x 6.6 in)
Heat Sink Dimensions (LxWxH) 154 x 140 x 153.5mm (6.1 x 5.5 x 6.0 in)
It's similar to a K2 Mount Doom which works well but I daren't stand the case up, I have a feeling the weight of the cooler might rip the mobo from its case mounting points :eek:
