With the PSU flipped, there's space for a fan down there. I'm just using the included bitfenix fan at the moment. The 6+2pin cables are just sitting around waiting to be put in permanent position. They could easily follow the fan edge and be tied to the mobo tray or be tied to the inside/outside of the 3.5" bays.
Yes, the SSD is held by one screw, and it's solid
All of those fans + cooler are being replaced, and fwiw, both of those large open framed Arctics fit up top with no issues.
Yep.
Thanks for your trouble Petey - much appreciated.
little condfused by image of your PSU, as label reads same way up as mine - but you have fan other way ? are the labels reversed on each side of PSU's?
Cheers again.
