I am really trying to limit my budget whilst building a Core2Duo system and my last port of call is the RAM. What i would really like to know is whether i would run into potential problems with a 9x333 fsb using a e4300 and only this ddr2-675mhz corsair memory. I will be buying a motherboard that is up to scratch (asus P5N-E SLI) so this shouldn't be an issue. It simply is a case of budget and the 666mhz are still considerably cheaper than the 800mhz modules. So 3ghz would be the maximum o/c that i would try to achieve anyway. Anyone else out there running this sort of combination?
one more thing...if i was running the e4300 and the corsair xms2 675mhz ram all at stock settings, would the ram be bottlenecking the cpu's performance as it is not running at the cpu's stated 800mhz (4x200)?
help would be greatly appreciated here.
