** CORSAIR 240 AIR - COMING SOON **
will this spec work
mobo?
2500k,
8gb ram,
2x sapphire toxic 6950(unlocked to 6970),
psu(what w will I need have a corsair hx620w and a cm real power m850w),
ssd/hdd,
ocuk h2flo(basically the corsair h60)
Thats pretty poor if true.
Id have expected at the very least 2x240 (one in front and the other in the roof) at minimum.
Will wait this one out until I decide if I want to change.
MiniITX is 2x240 in the front and bottom. MicroATX is 1x240 in the front. Don't think there is enough clearance for a 120 radiator at the top. A Corsair rep on another forum mentioned that it'd pretty easy to mod it though. It also has a 120 fan mount in the rear chamber as well apparently.
As far as I can tell there are no feet, so you should be able to simply turn it upside down :)
It comes with four adhesive rubber feet in the accessory box, so the user can apply them however they like, as well as the Corsair badge being magnetic.
If it was so easy to mod then why didnt corsair include it as standard.
It would make a good air build case but might not be as good as its bigger brother.
This thing is perfect and exactly what I've been wishing for, after seeing the Node 804's potential but ultimately microwave-size form factor.... Can't decide whether I will upgrade my crap cheap mATX case to this or the Enthoo EVOLV!
That is pretty awesome looking, been playing with the idea of going matx. This might just tempt me to go for it!
holy crap this case is awesome. Just been told to switch my htpc to this case so it can be the baby of the mrs gaming pc... and i never am one to argue when getting told to mess with pc's
Any idea when more stock is due of the black one?
I'm going to be putting a large order in in a few weeks and would like to use the case+psu free shipping deal with this case.
Just built my girlfriends rig using one of these in white.
So many awesome features, PCI slot bracket means no screws, top SSD mounts, HDD case at the back & removable with ease, loads of space for cables & PSU & plenty grommets + looks amazing.
Very good case, would recommend for any build.
