W3bbo you're spreading PSU hysteria.
The PSU he has is fine, it's got plenty of room for overclocking his CPU. He isn't "going to suffer overvoltage protection coming into play".
The PSU isn't the single most important part of the PC, this isn't 2004 any more. Virtually all PSUs are capable - the old designs with barely any 12V rail are long gone. The main difference between them is how close to the real rating they are, and how efficient/cool/noisy they are.
The hysteria that's spread about PSUs is ridiculous.
Up to it's limits for 24/7 usage? What nonsense are you talking about? The load figures are for a high end CPU running one of these 480s in Furmark - software specificially designed to get an unreasonably large power draw. Not only is he not going to run Furmark 24/7 he's also not even close to the max of the PSU.
However, I think this clearly demonstrates his setup exceeds his current psu rating and like I have said previous. His 520w may run it fine for a while but for long term use - I wouldn't risk it thats for sure.
[TW]Fox;18394862 said:I have the same PSU as him and ran almost the same spec but with an overclocked GTX280 instead of a 480 for 2 and a half years without a single problem with the PSU.
4 fans adds another 8W to things at worst. If he does have a soundcard and Anand doesn't, then it's another 10W.From what I can make out he has:
Overclocked Q6600 G0 @3ghz (assumed apx 1.3v - 130w load)
4GB DDR2
4 Hard drives (7200rpm assumed)
P35 motherboard
GTX480
Soundcard (Asus - assumed xonar PCIe 4x)
I think it is fair to also assume he has at least 3x120mm fans running (CPU, intake and exhaust). It's also fair to assume he has a minimum of 2 USB devices (Keyboard/mouse). There will most likely be more than this to take into consideration but I have used the bare minimum as an example.
This setup according to online psu calculators (which have actually been quite accurate compared to various systems I have used with much more accurate 'realtime' monitors) would draw around 570w (assumed 90% load when gaming). Unfortunately, I don't have the exact spec he has at present so cannot accurately predict how much power draw his pc would use.
Please don't misunderstand me. I'm not saying his pc will go up in smoke as soon as he plugs in the 480. It will likely be fine, at least for a while but the more stress he puts on the psu, the more likely it is to fail and as I have shown, he will most likely be running the psu above spec or at the very least very very close to it.
...and unlike you I am warning the OP of running a system that will stress his psu which at best might bring stability issues to his overclock and worse, possibly damage his hardware.[TW]Fox;18396612 said:I think that like most people in this thread you are simply guessing and you have no evidence at all to support your opinion![]()
. I'm not saying I'm right and everyone here is wrong, I'm saying in my experience running a psu close to it's limit (within 10%) is asking for trouble in the long term, maybe even sooner and the OP would be better served investing in a more powerful psu sooner rather than later if for nothing else but peace of mind.*SNIP*
This is where you have got things wrong. I have explained above why he isn't running close, or even near to the limit....and unlike you I am warning the OP of running a system that will stress his psu which at best might bring stability issues to his overclock and worse, possibly damage his hardware.
I see now why your popularity in motors precedes you.
This is where you're right.The more a psu is stressed, the more ripple will be created, especially as the majority of the consumption will be on the 12v rail(s). PSU ripple can have an effect on overclock stability and indeed pc stability in general, really bad ripple will damage hardware. As good as the corsair unit is (perhaps the best sub 600w psu out there), these voltage fluctuations cannot be avoided. Most modern psu's offer protection from this and will shut down before damage occurs, however there is no guarentee of this and one only has to read some of the harrowing tales of pc destruction on the net to realise this protection is not the safety net many believe it to be.
I don't need evidence when I have years of experience both testing hardware on a professional basis and as a hobby. I'm not saying I'm right and everyone here is wrong, I'm saying in my experience running a psu close to it's limit (within 10%) is asking for trouble in the long term, maybe even sooner and the OP would be better served investing in a more powerful psu sooner rather than later if for nothing else but peace of mind.
BANG !!!!!! ................OopsThe PSU is not something I would be worried about. I think its more than capable of running the 480.
I have 2 HDD's and a highly overclocked Q6600.
