So if you install a H100 into the 600T with the 2 fans above the rad (fans basically positioned outside the case under the top cover); is it best to have the fans exhausting hot air from inside the case through the rad (pull config), or have the fans blowing cold air through the rad into the case.
The 600T would be configured with the rear 120mm as exhaust and up to 4 fans as intakes on the sidemesh panel.
Thanks
Thanks
