** CORSAIR FORCE 3 SSDs ** PRE-ORDER NOW!!
20 Jul 2009
The bleak North East arm pit of Britain
The new high speed SandForce based Corsair Force 3 range of SSD is coming to OcUK.
PRE-ORDER yours now to ensure you get yours on release!
Corsair Force Series 3 120GB SATA 6Gb/s Solid State Drive (CSSD-F120GB3-BK) @ £184.99 inc VAT
Step up to SATA 6Gb/s performance with a Corsair Force Series 3 SSD. Your system responds better, boots quicker, and loads applications faster. Ideal for notebooks, Corsair SSDs run cooler and quieter than traditional hard drives, using less power.
- 120GB Capacity
- Sequential read speeds of up to 550 MB/s
- Sequential write speeds of up to 510 MB/s
- SATA 6Gb/s (SATA 3) connectivity
- High performance SandForce SF-2200 SSD controller
- Native TRIM support (O/S support required)
- RAID Support
- BGC (Background Garbage Collection)
Only £184.99 inc VAT.
ORDER NOW
Corsair Force Series 3 240GB SATA 6Gb/s Solid State Drive (CSSD-F240GB3-BK) @ £411.98 inc VAT
- 240GB Capacity
- Sequential write speeds of up to 520 MB/s
- RAID Support
Only £411.98 inc VAT.
ORDER NOW
According to Corsairs website it is 85,000 IOPS (4K aligned).
That is correct based on a 8GB LBA/s test but a 90% full drive (ie what you could end up with after some use + games etc) will be a little less.
Is that any good? (SSD noob)
Its up there with the best, edging out on the Agility 3 but (based on a used drive with OS etc) and a smidge behind the Vertex 3 with uses a different type of NAND.
60GB is unknown as yet but I wouldn't rule it out.
As for controller..
All the same as Vertex 3 and Agility 3.
nand in these is the same as the Agility 3 (Asyncronous) where as Vertex 3 is Syncronous.
well i've seen enough to cancel my 120gb agility 3 pre-order to pre-order one of these drives at a good price incase they go up. i've managed to get one in the basket for £169.99 delivered, cheaper than agility 3 too.
