Corsair Graphite 600T and GS Power Supply Bundles! - £25 off!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Corsair Graphite 600T Case and Corsair GS 600W Power Supply Bundle @ £174.98 inc VAT
The Graphite Series 600T is a mid-tower in height, but inside it’s positively cavernous. Easily accommodate even the longest graphics cards in the industry due to the reconfigurable hard drive bays. The increased space behind the motherboard tray allows clean, uncluttered cable routing. Up to six hard drive caddies, each of which can accommodate SSDs and standard mechanical disks, sit below the four 5.25" tool-free optical drive bays. If that weren’t enough, you can remove the top panel 200mm fan and install a 240mm radiator and dual 120mm fans for a quick watercooling upgrade.
- Twin 200mm cooling fans with white LEDs for excellent cooling
- Eight expansion slots provides you flexibility for multiple graphics card solutions
- Unique cable routing holes guarantees you a clean and clutter-free installation
- Integrated fan controller, for up to four fans, gives you the choice of noise vs. performance
- Motherboard compatibility: ATX and MicroATX
- Front I/O Ports: USB2.0 x 4, USB3.0 x 1, FireWire x 1, Audio x 2
- Cooling: 2 x 200mm white LED fans
- Tool-free optical drive installation makes building your system faster than ever
- CPU backplate cutout makes upgrading your CPU heatsink easy
- 2.5” and 3.5” hard drive compatibility for up to 6 drives — straight out of the box
- Two year warranty with Corsair’s world-class customer service and technical support
The Corsair Gaming Series GS600 power supply is the ideal price-performance solution for building or upgrading a Gaming PC. A single +12V rail provides up to 48A of reliable, continuous power for multi-core gaming PCs with multiple graphics cards. The ultra-quiet, dual ball-bearing fan automatically adjusts its speed according to temperature, so it will never intrude on your music and games. Blue LEDs bathe the transparent fan blades in a cool glow. Not feeling blue? You can turn off the lighting with the press of a button.
- It supports the latest ATX12V v2.3 standard and is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems
- An ultra-quiet 140mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature
- 80Plus certified to deliver 80% efficiency or higher at normal load conditions (20% to 100% load)
- 0.99 Active Power Factor Correction provides clean and reliable power
- Universal AC input from 90~264V — no more hassle of flipping that tiny red switch to select the voltage input!
- Extra long fully-sleeved cables support full tower chassis
- A three year warranty and lifetime access to Corsair’s legendary technical support and customer service
- Over Current/Voltage/Power Protection, Under Voltage Protection and Short Circuit Protection provide complete component safety
- Dimensions: 150mm(W) x 86mm(H) x 160mm(L)
- MTBF: 100,000 hours
- Safety Approvals: UL, CUL, CE, CB, FCC Class B, TÜV, CCC, C-tick
SAVING £25 INC VAT.
Only £174.98 inc VAT.
ORDER NOW
Corsair Graphite 600T Case and Corsair GS 700W Power Supply Bundle @ £184.99 inc VAT
The Corsair Gaming Series GS700 power supply is the ideal price-performance solution for building or upgrading a Gaming PC. A single +12V rail provides up to 56A of reliable, continuous power for multi-core gaming PCs with multiple graphics cards. The ultra-quiet, dual ball-bearing fan automatically adjusts its speed according to temperature, so it will never intrude on your music and games.
Tri-color LEDs illuminate the transparent fan blades at your command. Choose red, white or blue for the appropriate dramatic effect, or turn them off entirely at the press of a button.
SAVING £25 INC VAT.
Only £184.99 inc VAT.
ORDER NOW
Corsair Graphite 600T Case and Corsair GS 800W Power Supply Bundle @ £199.99 inc VAT
The Corsair Gaming Series GS800 power supply is the ideal price-performance solution for building or upgrading a Gaming PC. A single +12V rail provides up to 65A of reliable, continuous power for multi-core gaming PCs with multiple graphics cards. The ultra-quiet, dual ball-bearing fan automatically adjusts its speed according to temperature, so it will never intrude on your music and games.
SAVING £25 INC VAT.
Only £199.99 inc VAT.
ORDER NOW
600T,
the case of Win :D
Just purchased one of these:
Corsair Graphite 600T Window Panel @ £19.99 inc VAT
This replacement side panel features a clear window so you can see all your hardware while the case is closed. As an added bonus, we’re including a mesh insert. Simply remove the screws that hold the window in place, add the mesh side panel, and mount up to four (4) 120mm fans (not included) to boost your cooling performance!
- Graphite colored 600T side panel with clear window
- Metal hexagon mesh insert with rubber fan mounts
- Quick Start Installation Guide
Only £19.99 inc VAT.
ORDER NOW
Nice special you got going here Ace - come pay day (very skint now) one of those combos will be part of a new build I have planned.
I've pre-ordered the white version just before I saw these, however still undecided on PSU so still happy. The white version also comes with the new side panel so not too bad a deal :)
oooh that side panel is an option for sure....decent deals on the bundles too. Love my 600t case, sleek and regardless what the naysayers say...it does cool well :D
if stock holds out till I can afford it (next month some time) then I think I'll be picking one up as well. love it in white, its the only case I've ever seen that I think looks as good as my antec 300, and the cable routing looks incredible.
could anyone (from OCUK or otherwise) confirm how many of these are coming in, or roughly how many months they are expected to be available for?
Is there any chance you would do a bundle with the AX range of PSU's?!
I have been waiting and wanting to get a modular PSU and this case for AGES!
hey ace,fancy doing a deal on my 2nd hand 800d for this bundle ?
ill chcuk in some case as well to seal the deal.:):):)
