- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
The new H60 has landed and looks sure to prove a success. The weather is warm so to combat your CPU overheating, why not buy this high tech completely safe and secure enclosed water cooling loop.
Corsair Hydro H60 High Performance Liquid CPU Cooler (Socket LGA1366/1155/1156/775/AM2/AM3) @ £59.99 inc VAT
The Corsair Hydro Series H60 is a fantastic choice for cooling. With a new micro-channel cold plate and a split-flow designed manifold, the H60 brings remarkable new technologies to an affordable price point. If that weren’t enough, the H60 also features an all-new fan, custom designed to offer enhanced static pressure, which means better cooling.
You don’t have to sacrifice performance to build a quiet system. Most high-performance coolers use crude, outdated designs that rely on two techniques: put a huge hunk of metal in your case or crank the fan to obnoxiously loud noise levels. The Hydro Series coolers feature innovative, cutting-edge designs that utilize the superior thermal conductivity of liquid over air to provide fantastic cooling at much lower noise levels. In fact, the H60 is similar in noise levels to a 120mm case fan you probably already have.
Almost any case with a rear 120mm fan mount location can house the Hydro Series H60 CPU cooler. And don’t worry about compatibility with your CPU, we’ve got you covered. AMD® sockets AM2 and AM3 are covered, and without having to install a custom backplate, making the H60 a great choice for any modern AMD CPU up to the new Phenom six-core processors. And when it comes to Intel®, don’t worry about it. Whether you’ve got Socket LGA775, LGA1155, LGA1156, or LGA1366, we’ve got compatibility inside the box. That’s right, even the brand new Core i5 and Core i7 2x00 series processors are supported, right out of the box.
- Socket LGA1366 / 1155 / 1156 / 775 / AM2 / AM3
- Radiator Dimensions: 120mm x 152mm x 27mm
- Fan Dimensions: 120mm x 25mm
- Fan Speed: Up to 1700 RPM
- Fan Airflow: 74.4 CFM
- Fan dBA: 30.2 dBA
- Fan Static Pressure: 3.2mm/H20
- Cold Plate: Copper
- Radiator Material: Aluminium
Only £59.99 inc VAT.
ORDER NOW
- Fan dBA: 30.2 dBA
ORDER NOW
