** CORSAIR HXi DIGITAL FULL MODULAR POWER SUPPLIES NOW IN STOCK!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Corsair's latest and well priced digital HXi range is now in stock at OcUK. :)
Corsair HX750i Full Modular Digital Power Supply (CP-9020072-UK) @ £116.99 inc VAT
HXi Series power supplies give you extremely tight voltage control, virtually silent operation, and a fully modular cable set. With all Japanese 105°C capacitors, they’re a great choice for high performance PCs where reliability is essential. 80 PLUS Platinum efficiency reduces operating cost and excess heat, and together with Zero RPM Fan Mode technology, gives you virtually silent operation.
With Corsair Link Digital support, you can monitor power supply performance, toggle single rail or multi rail mode, and control fan speed directly from your desktop. And, the fully modular, low profile cable set makes builds and upgrades easy, with clean, great-looking results.
80 PLUS Platinum efficiency and Zero RPM Fan Mode mean that at low to medium loads, the fan doesn’t spin at all. And when you do push the HXi hard, the thermally controlled fan spins only as fast as it needs to.
But that’s not all. It’s quieter than most PSUs when the fan’s not spinning, too. The HXi is built with capacitors and other internal components specially selected to reduce coil whine and other electronic noise.
Connect the included cable to a motherboard USB header and download the free Corsair Link Dashboard application for Windows and you can monitor performance and efficiency, toggle single rail or multi rail mode, and control fan speed directly from your desktop.
The fully modular, low-profile cable set allows for quick and easy installation and great-looking builds. The fan self-test switch lets you quickly confirm operation before you even attach cables to your motherboard.
Features:-
- Corsair Link™ Integration for monitoring performance and adjustment of fan speed and multi-rail/single rail mode.
- 80 PLUS® Platinum efficiency, delivering 92% energy efficiency at real world load conditions.
- ZeroRPM mode for fanless operation at low loads and outstanding noise reduction.
- 140mm thermally controlled fluid dynamic bearing fan spins up as needed.
- Fully Modular low profile cables for easy installation, less clutter, and helps maximize airflow through your computer’s chassis.
- Engineered to meet maximum power output at a server-grade 50C temperature rating.
- Fan self-test switch to determine fan functionality even before installation.
- Over-voltage protection, under-voltage protection, and short circuit protection, over power protection, over temperature protection provide maximum safety to your critical system components.
- Safety and Agency Approvals: FCC, ICES, CE, UL / CUL, CSA, C-Tick/RCM, TUV, CB, CU, KC Mark, RoHS, WEEE, RoHS (China), REACH.
Specification:-
- 80 Plus Platinum
- Power: 750 Watts
- Fanless mode: Yes
- Fan bearing technology: Fluid Dynamic Bearing
- Fan size (mm): 140mm
- C-Link Digital: Yes
- Continuous output rated temperature (°C): 50°C
- ATX Connector: 150mm x 86mm x 180mm
- Modular: Yes
- Sleeved cables: Low-Profile, All Black
- ATX Connector: 1
- EPS Connector: 2
- Floppy Connector: 2
- Four Pin Peripheral Connector: 8
- PCI Connector: 6
- SATA Connector: 12
Only £116.99 inc VAT.
ORDER NOW
Corsair HX850i Full Modular Digital Power Supply (CP-9020073-UK) @ £131.99 inc VAT
Features:-
Specification:-
- 80 Plus Platinum
- Power: 850 Watts
- Fanless mode: Yes
- Modular: Yes
- ATX Connector: 1
- EPS Connector: 2
- Four Pin Peripheral Connector: 12
- PCI Connector: 6
Only £131.99 inc VAT.
ORDER NOW
Corsair HX1000i Full Modular Digital Power Supply (CP-9020074-UK) @ £155.99 inc VAT
Features:-
Specification:-
- 80 Plus Platinum
- Power: 1000 Watts
- Fanless mode: Yes
- Modular: Yes
- ATX Connector: 1
- EPS Connector: 2
- PCI Connector: 8
Only £155.99 inc VAT.
ORDER NOW
I love Corsair power supplies, the RM series was a bit of a disappointment though so these are exactly what I've been waiting for.
Good to have more options and that but as said above, Superflower any day of the week for a few quid more and more wattage.
Yep the Superflowers are over-engineered, the 1000W Platinum reviewed recently was running upto 1400W before it shut things down. They are excpeptional!
Are Superflower power supplies (Platinum Rate) not technically Titanium rated but there were released before Titanium was an offically recognised standard?
I could be wrong, but i though i seen that mentioned before somewhere
This is correct, they were built to me Titanium specification but at the time it did not exist, so they fall under Platinum. This is why they typically can do far more than what a typical 1000W PSU can do.
