Corsair Hydro H50 CPU Water-Cooler - Lowest UK Price!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Lowest UK price on the H50-1 Cooler from Corsair at OcUK.
Corsair Hydro H50-1 High-Performance CPU Watercooler (Socket LGA775/1155/1156/1366/AM2/AM3) @ £52.99 inc VAT
The Corsair Hydro Series™ H50 CPU Cooler gives you the power of liquid cooling in a compact, easy to install package. You get superior cooling for higher overclocking performance without the complexity of traditional liquid-cooling systems.
The Hydro Series H50 goes head-to-head with top of the line heatsinks, but maintains the near silence of liquid cooling for annoyance-free cooling performance. Due to its compact form factor, the H50 is the ideal solution for any case with a 120mm fan mount, even small form factor cases that prevent the installation of traditional heatpipe based air coolers. So whether you want world-class cooling, lower noise levels than your current CPU cooler, or something that fits in your small form factor case, the closed-loop Hydro Series H50 takes your CPU’s temperature to new lows and takes up less room doing it.
- Pre-filled, closed-loop system is easy to install
- Copper CPU cooling plate for maximum cooling performance
- Integrated pump and reservoir is sealed for zero maintenance and improved leakage protection
- Large 120mm radiator for fast heat dispersion
- High-efficiency, low-noise 120mm fan for drawing cool air across the radiator
- Two-year warranty
Only £52.99 inc VAT.
ORDER NOW
It was this price for the original H50 - which didn't have the mounting support for AMD or 1155/1156 sockets.
