** Corsair Hydro H80i GT - In Stock and Shipping NOW **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Corsair Hydro H80i GT High Performance Liquid CPU Cooler (CW-9060017-WW) @ £79.99 inc VAT
High-Performance CPU Cooling
Protect your hardware and increase your CPU’s overclocking potential. Dual fans and a double-thick radiator deliver outstanding cooling efficiency.
Advanced Fan Design
The 120mm fans use custom-engineered blades for better static pressure to noise ratio, offering improved performance at lower noise levels.
Corsair Link Monitoring and Control
Monitor temperature and control lighting and fan speed on your screen. No additional hardware is necessary.
Self-contained Cooling System
Hydro Series H80i comes pre-filled, and never needs refilling or priming.
Built-In Corsair Link
No additional hardware is necessary – just connect the included Corsair Link cable to a USB header on your motherboard and download the free Corsair Link Dashboard software. You can monitor coolant temperature and adjust cooling performance directly from your desktop.
Tool-free multiplatform magnetic mounting bracket kit
The modular design makes installation simpler, and it’s compatible with Intel and AMD processors.
Large-diameter, low permeability tubing
Minimal coolant evaporation helps ensure long life, and the resilient material offers both high flexibility and excellent leak protection.
- Extra-thick 120mm radiator: a depth of 49mm provides more surface area for rapid cooling.
- Improved coldplate and pump design: our latest generation is better than ever at rapidly drawing heat away from your CPU.
- Dual SP120L PWM fans: customizable performance and custom-molded blades for high static pressure with low turbulence.
- Flexible installation: use one of the included fans to save space, or use both for extra cooling power
- Modular, tool-free mounting bracket: installation is simple and straightforward.
- Built-in Corsair Link: adjust fan speed, monitor CPU and coolant temperature, and customize LED lighting directly from your desktop.
Only £79.99 inc VAT.
ORDER NOW
Got this coming tomorrow from OCUK! My first AIO Water cooler! Just hoping I can squeeze it into my Parvum Mini-ITX case!
Nice!! Fans are loud at full pelt m8 but pretty damn silent at 550rpm or so (I've set up a custom curve in Link)
That's what I like to hear! I don't really game any more so I am more about silence when I am on my computer.
Coming from an Noctua Air Cooler the only reason I am replacing it is that the Noctua is right up against my Graphics Card (GTX 960) and I am sure it is causing unnecessary heat build up and I have always wanted AIO.
Love mine, gave me approx 15c improvement on my H75 when at full pelt :)
