Corsair Obsidian 700D Full Tower Case
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys.
The 700D is back! With a great new price. Stock is arriving tomorrow.
Corsair Obsidian 700D Full Tower Case - Black @ £169.99 inc VAT
The steel structure has a matte black coating both inside out and is finished with a brushed aluminum faceplate for a professional look that’s both serious and awe-inspiring.
The power supply compartment, main compartment and the SATA bays each have dedicated cooling subsystems to prevent heat buildup.
A dust-filtered 140mm fan draws in cold air at the bottom of the chassis and exhausts it at the rear and top. This clever design forces fresh air directly over the graphics card and CPU. The hard drive / SSD bays are cooled by a separate 140mm fan which vents from the chassis via a sealed chamber and prevents the heat generated by the drives from entering the main compartment. The power supply compartment has its own dedicated intake and exhaust, also isolated from the main compartment.
Need even more cooling performance? The Obsidian Series 700D has pre-drilled support for top-mounted single, dual, and triple radiators, or up to three additional 120mm fans.
Advanced Features for Extreme Flexibility.
Six drive bays with clever snap-in trays accommodate both 3.5” and 2.5” drives with no adapter necessary. A unique cable routing system virtually eliminates cable clutter that can impede airflow. The tool-free design allows for easy entry, easy access, and quick installation of 5.25” drives.
- Six HDD / SSD drive bays compatible with both 3.5” and 2.5” drives
- Removable CPU backplate panel for easy heatsink installation
- Isolated cooling zones prevent heat buildup
- Unique cable routing holes guarantee a clean and clutter-free installation
- Three fans included, with the ability to add four more 120mm fans
- Tool-free optical drive installation makes building a system faster than ever
- Two year warranty with Corsair’s world-class customer service and technical support
- Dimensions: (609mm X 609mm X 229 mm)
- 5 x 5.25" Drive Bays
- 6 x 3.5" or 2.5" Drive Bays
- Front I/O: 4 x USB2.0, 1 x FireWire, 2 x Audio
Only £169.99 inc VAT.
ORDER NOW
Very nice - not sure about the price considering its not all alu
I paid a lot more when these first came out, alu is not big deal imho, PC enthusiasts dream build case, caters for the water cooler very well, aesthetically pleasing. It is large but still a fantastic case if you are a pc enthusiast, i'd recommend it 100%, top notch case from corsair.
Fair enough - im not really that fussed by alu, would have just expected it at that sort of price point. I guess the brushed faceplate is enough :)
I hear this is going EOL, is that true?
It does lack a niche really (since the 800D isn't that much more), and when the 650D comes out, there won't be much point to it in my opinion.
Looking forward to the 650D release though, don't think I'll be able to resist getting one!
