** COUGAR ATTACK X3 SPEEDY AND REVENGER S MOUSE LIVE NOW!!! **
OcUK Staff
23 Feb 2015
Overclockers UK HQ
Available to pre-order now and landing in the next week or so, from Cougar, The:
The Cougar Attack X3 RGB Speedy features Cherry MX Silver Switches, delivering super fast responsiveness, thanks to a shorter actuation point to minimise the time between press & activation.
The Attack X3 also packs RGB backlighting with 9 presets and with Cougar‘s UIX system you can create your own looks.
FEATURES:
× On-board memory with upto 30 macros
× Media keys for quick control
× 1.8m braided USB cable
× 467mm × 230m × 40mm (W × L × H)
Cougar Attack X3 Speedy RGB Gaming Keyboard Cherry MX Speed Switches - UK Layout @ £119.99 inc VAT
Cougar Attack X3 Speedy RGB Gaming Keyboard, UK Layout, Cherry MX Speed Switches, On-the-fly Mode Switch, 1000Hz Polling Rate, N-Key Rollover: Unlimited Accuracy, FPS Palm Rest
Only £119.99 inc VAT.
ORDER NOW
COUGAR REVENGER S
The Cougar Revenger S brings a staggering 2000Hz poling rate, without overclock, for ultra-precise gameplay, communicating to your PC every 0.5 milliseconds for as close to real-time tracking as possible.
With an ergonomic shaping and layout, it‘s supportive rear arch is comfortable for all styles of gaming and it‘s buttons are easy to access in the clutch.
FEATURES:
× PixArt PMW3360 optical gaming sensor
× 6 programmable buttons
× 1.8m USB cable with gold-plated connector
× 65mm × 130m × 43mm (W × L × H)
Cougar Revenger S Optical RGB USB Gaming Mouse - Black @ £64.99 inc VAT
https://www.overclockers.co.uk/cougar-revenger-s-optical-rgb-usb-gaming-mouse-black-kb-03p-cu.html
Cougar Revenger S Optical RGB USB Gaming Mouse - Black, Real 12000 DPI, Advanced Button Design, Anti-Slip Real Rubber Flanks, Polling rate: 2000Hz
Only £64.99 inc VAT.
ORDER NOW
