- 26 May 2003
- Berkshire
Right just replaced my 7800GTX with a shiny new X1900XT (I didn't do a reformat/install, but comphensively removed any signs of the old NVidia drivers and used DriverCleaner) - its been a while since I had an ATI card although I must admit for some strange reason ever since the 9800Pro I have felt more "at home" with ATI cards.
Running the 6.2 drivers with CCC to my TFT via DVI and have a couple of potential issues.
I notice that with recent versions of CCC they seem to have shifted a lot of the .NET framework load lag to the machines startup rather than just when you try to use CCC.
First thing is that when CCC appears to load (and the taskbar icon loads) the screen blanks briefly - similar to how I remember it always used to when changing Direct3D settings in CCC or the old control panel. Is this normal and could it be because CCC only reloads my preferred settings when it loads after Windows login rather than before? Anyone else have this?
Second is a couple of exceptions in the ACEEventLog at startup:
0000000001: 2006-03-03 09:39:48:437 Client already registered
Error Called by: ATI.ACE.CLI.Component.Runtime.Shared.RTAdapters::add_AdapterValueUpdated
and
0000000002: 2006-03-03 09:39:49:062 Exception <registering into Radeon X1900 Series.AdapterValueUpdated>: From method (add_AdapterValueUpdated) message (Client already registered)
Exception Called by: ATI.ACE.LOG.Foundation.Service.Service::CombineClientIntoList
Anyone else seen these before?
and
