Coupling KEF KIT100 with a Samsung Bordeaux LCD TV
20 May 2004
First post in this forum — apologies if this is a dumb question!
I'm about to order a Samsung LE32R87BDX Bordeaux 32" LCD TV to replace an ancient 19" LCD TV. A much overdue upgrade!
On my old TV I only seem to be able to get my KEF KIT100 sound system working when watching DVDs.
It all goes through a SCART connection but other options are available at the back of the unit:
Should I be looking at using these outputs instead? If so, which?
Thanks for looking :)
On the back of the samsung you will have 2 audio out sockets that will output the sound from whatever you are watching.
There is also a optical output you could use if you wanted to.
