** CPU COOLER DEAL - Zaward Vapor 120 @ £19.99**
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
We have a brilliant price on the Zaward Vapor 120 Multi Socket CPU Cooler online for preorder now.
£19.99 gives you access to a CPU cooler with a very high end fan. This is not a deal to be sniffed at!
Performance is on par or better in some circumstances than the Titan Fenrir, a cooler which is much more expensive and noisier.
Zaward are a brilliant brand and an OEM for other manufacturers famous 'golf ball' fans ;)
Stock is due to land early next week
whet your appetite with this review on tech powerup!
This cooler fits LGA775/LGA1156/LGA366/AM2/AM2+/AM3 sockets also!
Zaward Vapor 120 Multi Socket CPU Cooler (Socket: LGA775/LGA1156/LGA366/AM2/AM2+/AM3/754/939/940) @ £19.99 inc VAT
The Zaward Vapor 120 offer excellent cooling properties and is supplied with a single golf ball style 120mm fan, you can fit a second fan to this heatsink to improve the cooling performance even further using the tried and test push-pull method.
- Socket: LGA775 / LGA1156 / LGA1366 / AM2 / AM2+ / AM3 / 754 / 939 / 940
- Dimension: 20 (W) x 50 (D) x 160 (H) mm
- Fin: Aluminum alloy with 3 x 8mm copper heatpipes
- Base: Aluminum with H.D.T
- Dimension: 120 x 120 x 25 mm
- Bearing type: Long life Duro bearing
- Speed: 300±200 rpm ~ 2000±10%
- Air flow: 93.96 CFM max.
- Noise level: 10~34.3 dBA
- Connector: 4 pin with PWM function
- LED: 4 blue
- Life Expectancy: 60,000 hours
- Thermal resistance: 0.15 °C/W
- Weight: 684g
Was £29.99 Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
You are preaching to the choir mate. Vapor is a brilliant cooler.
Did comparison test with Gelid Tranquillo and Zaward Vapor was actually 2c cooler on Athlon II X4 620 stock @ 2.6GHz.
Overclocked the 620 to 3.5GHz at 46c on prime.. and that is the only time I hear it running.
the Alpenfohn Triglav is available on our webstore but is a little more expensive than the Zaward.
that said, there is definitely a lot of choice in the sub £30 cooler range now
