5 Oct 2010 at 18:00 #21 kedge kedge Soldato Joined 5 Sep 2010 Posts 3,753 The problem i have had in the past with amd mainboards is that some larger type air coolers won't fit if you have high heatsinks on ram modules.
5 Oct 2010 at 20:42 #22 GoogalyMoogaly GoogalyMoogaly Soldato Joined 29 Aug 2010 Posts 8,195 Location Cornwall gillywibble said: My Fenrir vents to the back of the case. Click to expand... With an AMD chip? I thought they blew up with AMD and sideways with Intel, although the Intel might do either.
6 Oct 2010 at 12:37 #23 Angel_Rex Angel_Rex Associate Joined 8 Dec 2004 Posts 878 Location Brighton - East Sussex GoogalyMoogaly said: With an AMD chip? I thought they blew up with AMD and sideways with Intel, although the Intel might do either. Click to expand... Not if u use the back plate. also depend on the original socket orientation - from what i was led to believe.
