cpu temps on my first build
8 Dec 2011
hello there i have just built my first computer heres the specs to start off
cm sniper case
ASUS 1155 P8Z68 DELUXE S/L
Intel Sandybridge i7-2600K running @ 4.8 ghz oc
Corsair CMPSU-800GUK Gaming Series GS800 High Performance 800W Power Supply
Asus 1GB GeForce GTX 560TI DirectCUII PCI-E Graphics Card
16 gb of corsair vengance ram
Corsair CWCH60 Water Cooler
under idle conditions its around the 30 degree c mark but when running prime 95 it gets to around 77 - 80 this seems hot to me as im new to this is this normal thanks a lot
james
26 Aug 2011
H60 should keep your CPU temp below 60-70 depends on V core.
What V-Core are you using?
Try re sitting heat sink, and re apply thermal paste.
OP
8 Dec 2011
iv over clocked with asus ai suite ii so the v core keeps changing all the time ill try re sitting the heatsink now if it sorts it ill let you no
