Cracked Monitor? Scary Thought! Get Protected
22 Aug 2010
Keep your screen protected on the go with the Roccat Tusko Flatscreen/Widescreen Bag fantastic padded carry case. Intergrated protection plate effective protection during transportation, so feel at ease when carrying your expensive monitor to LAN's and other events.
Roccat Tusko 20 - 24 Inch Across-the-board Flatscreen/Widescreen Bag @ £39.98 inc VAT
Arrive at your next LAN party safe and secure. The ROCCAT™ Tusko Across-The-Board Flatscreen Bag isn’t just large enough to accommodate your 20 - 24-inch widescreen monitor; it’s also got enough space for your keyboard, mouse and accessories.
SAFETY FIRST:
While also offering the highest level of protection. The integrated rigid plastic plate provides effective protection against shocks – and water and dirt don’t stand a chance either. The water repellent material, featuring high quality stitching, is secured together using clip hooks and the intelligent Clip’n’Go system. To compensate for the greater weight of a widescreen monitor the ROCCAT™ Tusko Across-The-Board Widescreen Baghas an integrated Protection Plate Plus which guarantees a completely shock-proof transport at any time.
- Clip'n'go system for 20 - 24-inch widescreen monitors
- Intergrated protection plate effective protection during transportation
- Premium woven material water and dirt repellent
- Extra holder for keyboard with 3 or 4 additional pockets for accessories
- Intelligent securing system, secures the monitor at 4 points to prevent it sliding around
- high quality snap hooks, a rugged carrying strap, hard plastic handle and rubberized shoulder pad
Only £39.98 inc VAT.
ORDER NOW
Roccat Tusko 15 - 19 Inch Across-the-board Flatscreen/Widescreen Bag @ £25.98 inc VAT
SAFETY FIRST:
- Clip'n'go system for 15 - 19-inch widescreen monitors
Only £25.98 inc VAT.
ORDER NOW
I have one of the 24" versions bought from a competitor last year. They are very good products, and the advantage over the original box is if its raining as you are transporting it then it wont turn into a puddle of paper mache :D
Plus there is room for cables and a mouse and also a holder for your keyboard. Aswell as the shoulder strap to make it easier to carry :D And you dont have to detach the monitor stand every time you want to transport it
Nice LAN bags. These are ifficult to get tbh!
I bought my brother one after his screen got a crack/dent transporting it back from a LAN.
