Hiya Boys N Girls
My Spec:
Gigabyte GeForce GTX 770 WindForce 3x OC 2048MB GDDR5
Gigabyte Z87X-UD3H Intel Z87 (Socket 1150) DDR3
Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150
Corsair Hydro H100i High Performance Liquid CPU Cooler
Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (PV38G240C0K)
Asus Xonar DGX 5.1 PCI-Express Sound Card with built in Headphone Amp
Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW)
Corsair HX Series HX750 Power Supply — 750 Watt
Crucial 64GB Real SSD C300 (Games)
Crucial 128GB Real SSD C300 (OS)
2x Samsung SpinPoint F3 1TB SATA-II 32MB Cache (Data)
OS Windows 7 Pro with all updates.
Corsair Vengeance K95 Mechanical Gaming Keyboard
Razer Deathadder 3.5G
Corsair Vengeance 1400 Gaming Headset
I am not nor have I ever overclocked this hardware as I don't play any games that would benefit from it.
So to the problem, I have been having murder with crashing to desktop from my game of choice World of Tanks. I have been using windows event viewer to try and determine the errors. Every time without fail it is:
Faulting application name: worldoftanks.exe, version: 0.9.0.0, time stamp: 0x53708a09
Faulting module name: nvd3dum.dll, version: 9.18.13.2723, time stamp: 0x52314d4c
Exception code: 0xc0000005
Fault offset: 0x006082b3
Faulting process id: 0x1054
Faulting application start time: 0x01cf73074dc31f5d
Faulting application path: C:\Games\World_of_Tanks\worldoftanks.exe
Faulting module path: C:\Windows\system32\nvd3dum.dll
Report Id: 34ab758e-defb-11e3-9e4f-94de80771b46
It normally will only crash to desktop when the PC has just been turned on. And what I mean by just turned on is that I will come in from work, turn pc on check emails maybe look at some forums, watch a few youTube videos etc. I will then log into TeamSpeak get in the clan wars channel say some hi's. Maybe play a few rounds whilst the turns are being calculated for clan wars. Without fail I will get into battle and within 3 minutes I will have crashed to desktop. It manifests itself with a “lag” like happening, so it feels like a rubber banding moment but instead of you coming back from that rubber banding you will get a white screen with the windows pop up “program has stopped responding and needs to close”. If I go straight to event viewer then I will see the above error every time.
If I then cancel this window, this will close WoT and I can click straight away the WoT icon on desktop go through the game launcher and get back into the same game I crashed out of IF I haven't died and play the rest of the night without a problem. It seems it will only fail on the 1sr turn on of the machine and then after that it's ok.
I have tried:
fresh OS installs
installing WoT in differnet locations
playing with and without game mods
lowering in game res.
lowering in game render quaility
having everything on LOW/OFF even though my card is quite capable of MAX with everything on.
I have tried many different drivers and even gone back to the driver set before the R331 game ready generation (GeForce 327.23 Driver WHQL 327.23 19.9.2013). I also installed just the driver and none of the extra Nvidia experience, 3D, Sound drivers and for 3 days I didn't crash to desktop, so I stupidly announced in TS “I've fixed it finally” then the very 1st game I played after switching the pc on the next day, boom Crash to Desktop! (FYI the pc had been on and off the last 3 days without incident).
Running the game as admin.
I have minimal software running in the back ground as user installed. I run Avast AV and use Windows firewall. I have Core Temp although I already knew I wasn't over heating since I don't get above 50 degrees the same story with the GPU the fan barely increase rpm and it doesn't get hotter than 70 degrees.
Generally speaking I wouldn't call myself a computer “noob” I have been building my own pc's since 1992 but a person on the bleeding edge I am not either. I like most am quite capable of googling and finding answers 99% and don't require any extra help, but with this I am just going around and around in circles.
My Spec:
I have tried:
fresh OS installs
