Crazy SSD Deal on Corsair Force LS Series 60GB 2.5" SATA 6Gb/s
22 Apr 2014
Have you been sat on the fence wondering whether to go SSD or not in your PC or Laptop. Well now is the time to try SSD and discover the amazing boot times and the speed with which applications launch. For just £31.99 you can get a 60GB SSD from Corsair which will be more than enough to install your OS and office and other programs to get you up and running. This is a perfect price to try out an SSD. Once you have gone SSD you will not go back.
This is a pre-order deal and I will have stock landing today before 6PM so orders will ship out tonight if you get them on early enough. I have limted numbers so get ordering quick.
Corsair Force LS Series 60GB 2.5" SATA 6Gb/s Solid State Hard Drive (CSSD-F60GBLS) @ £31.99 inc VAT
Force Series LS provides solid performance at great value, as well as a reliable solid-state storage for any PC or notebook with a standard 2.5” drive bay. It’s also backward compatible with SATA 2 and SATA 1 for maximum compatibility. The thin 7mm height, low heat generation, reliable solid-state design drive make it ideal for all applications, from desktop PCs to the ultra-thin notebooks.
- Sequential read speeds of up to 550 MB/s
- Sequential write speeds of up to 535 MB/s
- SATA 6Gb/s (SATA 3) connectivity
- High performance Phison controller
- Native TRIM support (O/S support required)
- RAID Support BGC (Background Garbage Collection)
- Increased reliability and quieter operation over standard hard disk drives
- Significantly lower power usage than traditional hard drives for increased notebook battery life
- 2.5" form factor for your portable computer needs
- 3 year warranty
Crystal Disk Mark
Sequential- Read 540
Sequential- Write 190
512K- Read 383
512K- Write 111
4K- Read 44
4K- Write 75
4K QD32- Read 165
4K QD32- Write 79
IO Meter
4K RR IOPs 47000
4K RW IOPs 24000
ATTO v. 2.41
Max Read 528
Max Write 446
Anvil 1.1.0
Max score 2685
Was £41.99 Inc. VAT
Only £31.99 inc VAT.
ORDER NOW
Still a bit over the price mark I would pay for 60gb when I can get 120gb for only another £10.
£25 for me is correct price point for these.
Is this SSD backwards compatible with Sata II?
I bought a 512GB MX100 for my donkeys old Q9300 system and it made a massive difference...
But might consider this as a boost for my better half's Opteron 165(?)/ Asrock Dual SATA II system (my ~2005 machine, that somehow still plays Sims 4 and Civ BE ok!)
For an entry level SSD for someone starting out and wanting to see what the power of a SSD can do then this is the cheapest option. As they will already have a mechanical drive in the machine they could then use that for the storage drive. That was you will not need the larger SSD
