- 29 Sep 2003
- Newcastle upon Tyne
Hi all
I had my toilet replaced yesterday as the other one was broken. The issue is, the wall where the cistern attaches is very poor quality, and is just crumbling away. Overnight, this has caused the cistern to come away from the wall by about 1cm. One of the screws holding the cistern to the wall, which was tight yesterday right after installation, is now very loose, and when wobbled, you can hear the wall crumbling onto the floor behind.
I want it fixed, and I want it fixed properly. Will this part of the wall need replastering, or is there some other solution to the problem?
Many thanks
Michael.
Many thanks
Michael.
